AW: Re: AW: Re: [Qgis-developer] provider.getNextFeature(fet) with PostGIS
Düster Horst Horst.Duester at bd.so.ch
Wed Feb 13 07:45:26 EST 2008
Here is the complete code:
  def makeIntersection(self, writer, vlayerA, vlayerB):
    providerA = vlayerA.getDataProvider()
    providerB = vlayerB.getDataProvider()
    featA = QgsFeature()
    featB = QgsFeature()
    allAttrsA = providerA.allAttributesList()
    allAttrsB = providerB.allAttributesList()
#select only to the intersection square of the bounding boxes
    combinedExtent = vlayerB.extent().intersect(vlayerA.extent())
    providerA.select(allAttrsA, combinedExtent)
    providerB.select(allAttrsB, combinedExtent)
# Detect the number of all involved objects for later use
# with progressbar (nFeat)
    tmpIndexA = self.createIndex(providerA)
    tmpIntersectsA = tmpIndexA.intersects(vlayerB.extent())
    tmpIndexB = self.createIndex(providerB)
    tmpIntersectsB = tmpIndexB.intersects(vlayerA.extent())
    nFeat = len(tmpIntersectsA) + len(tmpIntersectsB)
    index = self.createIndex(providerB)
    nElement = 0
    self.geo_ctrl.progressBar.setValue(0)
    self.geo_ctrl.progressBar.setRange(0, nFeat)
    providerA.getNextFeature(featA)
    attribA = featA.attributeMap()
    geomA = featA.geometry()
    print "N-Features: "+str(providerA.featureCount())
    print "Geomtry: "+geomA.exportToWkt()
    print "AttributeMap: "+str(attribA)
    return 0
Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Marco Hugentobler [mailto:marco.hugentobler at karto.baug.ethz.ch]
Gesendet am: Mittwoch, 13. Februar 2008 13:00
An: Düster Horst
Cc: qgis-developer
Betreff: Re: AW: Re: [Qgis-developer] provider.getNextFeature(fet) with
And what were the arguments you provided for the select() call of the
provider?
Marco
Am Mittwoch 13 Februar 2008 12:52:34 schrieb Düster Horst:
> Code and corresponding outputs with respect to an example postgis
layer:
>     print "N-Features: "+str(provider.featureCount())
> # Output: "N-Features: 4 "
>     provider.getNextFeature(feat)
>     attrib = feat.attributeMap()
>     geom = feat.geometry()
>     print "Geomtry: "+geom.exportToWkt()
> # Error message: AttributeError: 'NoneType' object has no attribute
> 'exportToWkt'
>     print "AttributeMap: "+str(attrib)
> # Output: "AttributeMap: {}"
> The number of features is correct but no geometry and no attributeMap
> Regards
> Horst
> Dr. Horst Düster
> Kanton Solothurn
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Gesendet am: Mittwoch, 13. Februar 2008 12:39
> An: qgis-developer at lists.osgeo.org
> Cc: Düster Horst
> Betreff: Re: [Qgis-developer] provider.getNextFeature(fet) with
> I recently did some changes in the postgres provider to enhance
> efficiency.
> Maybe this is a side-effect of my changes? It would therefore be
> interesting
> to know what exactly does not work. Is the geometry empty? Or the
> attribute
> information missing? Also, it would be good to know the arguments you
> passed
> to 'getNextFeature'.
> As it works with .shp layers, I think it is very unlikely that it is a
> python
> bindings problem.
> Regards,
> Marco
> Am Mittwoch 13 Februar 2008 12:14:29 schrieb Düster Horst:
> > Martin
> > Thank you for Rev. 8153 now setAttributeMap() works fine. But now
I'm
> > faced with the next problem.
> > provider.getNextFeature()
> > doesn't work no more with PostGIS layers. It works fine with *.shp
> > layers.
> > Maybe the same issue like setAttributeMap()???
> > Geoprocessing Plugin:
> > >In my opinion you can put your plugin to the repository, maybe some
> > >people would like to join your efforts!
> > How can I put the plugin to the repository??
> > Regards
> > Horst
> > Dr. Horst Düster
> > Kanton Solothurn
> > SO!GIS Koordination
> > Rötistrasse 4
> > CH-4501 Solothurn
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080213/e804072c/attachment-0001.html
