[Qgis-developer] Planning for QGIS 1.0.0 '????'
Jürgen E. Fischer
jef at norbit.de
Thu Jul 31 16:26:58 EDT 2008
Hi Tim,
I filed a ticket about this [1]. It includes links to the GEOS ticket,
changeset and the qgis patch.
On Thu, 31. Jul 2008 at 14:04:46 +0200, Tim Sutton wrote:
> Ways to address it:
> - patch upstream geos and wait for change to get into repos (loooong
> time?)
There's already a changeset, so that didn't take that loooong. But you
are right: I don't know when the next GEOS release is and when the
distributions will pick the new release up.
> - figure out a workaround to be able to use unpatched geos
The GEOS patch only adds a C-API call to get the cut edges from the GEOS
polygonizer. Which is only used for splitting polygons for
QgsMapToolSplitFeatures (see src/core/qgsgeometry.cpp:4689 [2]).
I must admit, that I'm not really sure if it's just a sanity check,
which we might - at least temporary - disable. Or disable (again
temporarily) the whole split feature feature.
Jürgen
[1] http://trac.osgeo.org/qgis/ticket/1193
[2] http://doc.qgis.org/classQgsGeometry.html#f7c34f79bac9b647d0700bd7e43fe673
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
