[Qgis-developer] the new plugin installer
Borys Jurgiel borys at wolf.most.org.pl
Sun Jun 1 12:19:59 EDT 2008
Sunday 01 of June 2008 17:32:37 Martin Dobias napisał(a):
> Thanks for the effort! I've tried finally the plugin installer as
> you've modified it and looks fine with my few tests.
Thanks, have you tested it under Windows/Mac? Now it's coming into beta stage,
but I've tested it mainly under Ubuntu. Could anybody test it under something
else?
> > We have there 43 plugins and in only 17 cases the name in the repository
> > and the one inside plugin are the same. Until now it wasn't so important,
> > but now we will have to pay more attention to the name and version
> > number, because Installer identifies plugins by the name.
> This shouldn't be necessary. We can identify plugins by the plugin's
> directory - it's simple, easy and don't need any changes.
I can't agree. There is no information in repositories about instalation
directories. The Installer would have to open every zip file for compare with
module name, so it would be very slowly!
Furthermore, even if we had two different plugin names and/or two different
version numbers, associated by the installation folder name, which name and
version should I use? And how should I know, when the difference between
version numbers is due to upgrade in repository, and when due to the
mistake? :)
Nooo, we need to have a clearness.
> Looking at your code I see you use python's reload() method to reload
> the plugin. This doesn't work as expected. The only way how to
> completely reload some module in python is to delete it first and then
> import again:
> del sys.modules['plugin_dir']
> import plugin_dir
Great thanks! The reload() was necessary for refreshing version number inside
Installer, but still I didn't find any way to completely reload the plugin in
whole QGIS without need of restarting. I understand this way should be
sufficient?
> I have some more GUI-related comments:
> - versions in the table should IMHO go before the description column,
> so one can see them without scrolling to the right
> - that label and text field "name of plugin to install" are not
> neccessary, better remove them
> - we should allow sorting in plugin list
Thanks for the suggestions, I'll implement them. The line "name of plugin to
install" will be replaced with a filter line.
> Good job, hope to see some further work - especially uninstallation of
> plugins would be very useful.
Give me two or three hours! ;) I've done a fair piece of changes already, I'm
going to submit they in a few hours.
