[Qgis-developer] compiling 1.0
Jürgen E. Fischer jef at norbit.de
Mon Sep 8 10:06:09 EDT 2008
Hi Paolo,
On Mon, 08. Sep 2008 at 09:18:09 +0200, Paolo Cavallini wrote:
> - the grass plugin starts, but when opening the toolbox, I get:
> The config file (/grass/config/default.qgc) not found.
> the file is both in the src dir, in the original
> /usr/share/qgis/grass/config/default.qgc (I still have 0.11 installed as
> root), and where I installed the app:
> /home/paolo/Desktop/qgis/share/qgis/grass/config, so what?
Do you have the -dev packages installed?  If so, you need to remove them
first, otherwise the fresh build will pickup the old header files.
BTW you can also build debian packages by running
	dpkg-buildpackage -us -uc -b
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
