[Qgis-developer] don't find /resources/srs.db and /grass/config/daefault.qgs
Otto Dassau otto.dassau at gmx.de
Wed Sep 17 07:33:33 EDT 2008
On Wed, 17 Sep 2008 12:10:32 +0200
Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch> wrote:
> Hi Otto,
> I had the same problem recently and it turned out that, besides the current
> version,  there was a 0.11 version of libqgis_core.so on my system. So it
> seemed that the linker sometimes took the wrong one. Removing the old library
> version and recompiling solved the issue for me.
Thanks a lot Marco. After cleaning up everything works fine!
regards,
 Otto
> Regards,
> Marco
> Am Mittwoch 17 September 2008 12:01:03 schrieb Otto Dassau:
> > Hi,
> > I have 2 problems with a current svn QGIS build on ubuntu/debian:
> > a) when I start the GRASS toolbox it says:
> > the config file /grass/config/default.qgs not found, although it is there
> > at /usr/local/share/qgis/grass/config/default.qgs
> > b) when I want to search for a projection in the CRS Dialog it says:
> > Error reading database file from /resources/srs.db, but is there at
> > /usr/local/share/qgis/resources/srs.db
> > Do I have to define another path somewhere during configuration? For my
> > configuration I use alomost the same CMAKE options as written in
> > debian/rules:
> > -Wno-dev \
> > -D CMAKE_INSTALL_PREFIX=/usr \
> > -D CMAKE_SKIP_RPATH=TRUE \
> > -D GRASS_PREFIX=/usr/local/grass-6.3.1svn \
> > -D BINDINGS_GLOBAL_INSTALL=TRUE \
> > -D PEDANTIC=TRUE
> > thanks a lot
> >   Otto
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
