[Qgis-developer] don't find /resources/srs.db and /grass/config/daefault.qgs
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Wed Sep 17 06:10:32 EDT 2008
Hi Otto,
I had the same problem recently and it turned out that, besides the current
version,  there was a 0.11 version of libqgis_core.so on my system. So it
seemed that the linker sometimes took the wrong one. Removing the old library
version and recompiling solved the issue for me.
Regards,
Marco
Am Mittwoch 17 September 2008 12:01:03 schrieb Otto Dassau:
> Hi,
> I have 2 problems with a current svn QGIS build on ubuntu/debian:
> a) when I start the GRASS toolbox it says:
> the config file /grass/config/default.qgs not found, although it is there
> at /usr/local/share/qgis/grass/config/default.qgs
> b) when I want to search for a projection in the CRS Dialog it says:
> Error reading database file from /resources/srs.db, but is there at
> /usr/local/share/qgis/resources/srs.db
> Do I have to define another path somewhere during configuration? For my
> configuration I use alomost the same CMAKE options as written in
> debian/rules:
> -Wno-dev \
> -D CMAKE_INSTALL_PREFIX=/usr \
> -D CMAKE_SKIP_RPATH=TRUE \
> -D GRASS_PREFIX=/usr/local/grass-6.3.1svn \
> -D BINDINGS_GLOBAL_INSTALL=TRUE \
> -D PEDANTIC=TRUE
> thanks a lot
>   Otto
> Qgis-developer mailing list
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
