[Qgis-developer] QGIS 1.1 testing
Alex Mandel tech_dev at wildintellect.com
Wed Apr 29 05:13:11 EDT 2009
Could you post your ccmake alterations you used to tell it which GRASS
and GDAL to use?
Thanks,
Alex
Giovanni Manghi wrote:
> Hi,
> I have built rev. 10654 on Jaunty 32 bit (with grass 6.4rc4) and I'm
> experiencing none of the referred problems.
> -- Giovanni --
> On Tue, 2009-04-28 at 17:42 -0700, Alex Mandel wrote:
>> These tests were done with Release 1 1 branch built on Ubuntu 8.10
>> 32bit, installed into /home/user/apps/
>> Attribute table actions buttons are all missing their logos.
>> GRASS Plugin always starts off for some reason.
>> GRASS opening the toolbox give a /grass/config/default.qgc not found.
>> Hence module List etc are missing.
>> (I'm guessing I missed something in the grass-plugin build)
>> -Tried both libgdal1-dev 1.6.0-1 and libgdal1-dev 1.5.4-2
>> -These are working fine in my repo pulled versions of qgis
>> -tried with GRASS 6.3 and custom 6.4
>> Spatialite works but fails to detect geometry type in all tests
>> including the example database provided from spatialite's website.
>> *.db is also a common extension for sqlite, works fine if all files is
>> selected and a .db sqlite file is picked.
>> Why is spatialite on the file menu instead of the database menu. It's
>> not more or less of a database than the ESRI personal geodatabase(also a
>> single file)?
>> Just some notes as I work my way through, same issues with trunk.
>> I think the grass stuff is a build error on my part, not sure how to
>> correct and the spatialite stuff are just things to work on, but not
>> holding me up at all.
>> Thanks,
>> Alex
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
