[Qgis-developer] QGIS 1.1 testing
Giovanni Manghi giovanni.manghi at gmail.com
Wed Apr 29 05:21:24 EDT 2009
I basically followed my own instructions
http://wiki.osgeo.org/wiki/Instalar_Grass_6.4_e_QGis_1.0_em_Ubuntu_8.10_(com_ECW_e_MrSID)
sorry, they are in Portuguese but code and commands should be pretty
clear. I just made the necessary changes to use the new grass RC and
qgis unstable instead of the stable source code.
-- Giovanni --
On Wed, 2009-04-29 at 02:13 -0700, Alex Mandel wrote:
> Could you post your ccmake alterations you used to tell it which GRASS
> and GDAL to use?
> Thanks,
> Alex
> Giovanni Manghi wrote:
> > Hi,
> > I have built rev. 10654 on Jaunty 32 bit (with grass 6.4rc4) and I'm
> > experiencing none of the referred problems.
> > -- Giovanni --
> > On Tue, 2009-04-28 at 17:42 -0700, Alex Mandel wrote:
> >> These tests were done with Release 1 1 branch built on Ubuntu 8.10
> >> 32bit, installed into /home/user/apps/
> >> Attribute table actions buttons are all missing their logos.
> >> GRASS Plugin always starts off for some reason.
> >> GRASS opening the toolbox give a /grass/config/default.qgc not found.
> >> Hence module List etc are missing.
> >> (I'm guessing I missed something in the grass-plugin build)
> >> -Tried both libgdal1-dev 1.6.0-1 and libgdal1-dev 1.5.4-2
> >> -These are working fine in my repo pulled versions of qgis
> >> -tried with GRASS 6.3 and custom 6.4
> >> Spatialite works but fails to detect geometry type in all tests
> >> including the example database provided from spatialite's website.
> >> *.db is also a common extension for sqlite, works fine if all files is
> >> selected and a .db sqlite file is picked.
> >> Why is spatialite on the file menu instead of the database menu. It's
> >> not more or less of a database than the ESRI personal geodatabase(also a
> >> single file)?
> >> Just some notes as I work my way through, same issues with trunk.
> >> I think the grass stuff is a build error on my part, not sure how to
> >> correct and the spatialite stuff are just things to work on, but not
> >> holding me up at all.
> >> Thanks,
> >> Alex
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
