[Qgis-developer] PyDev
Maurício de Paulo mauricio.dev at gmail.com
Wed Dec 30 09:27:06 EST 2009
Sorry for the wrong information.
On my ubuntu 9.10 eclipse already found Qt. I think that if it's recognized
in the PythonPath on PyDev's Preferences it loads the API. Eclipse takes a
looooong time trying to index the APIs available for a given python
instalation.
I'm going to try it on windos vista later.
Best regards,
Mauricio de Paulo
2009/12/30 Maurício de Paulo <mauricio.dev at gmail.com>
> Indeed. I know that there is some way to make pydev search everything and
> build autocomplete, but I haven't looked much into it. I don't really use
> autocomplete... And eclipse is a really demanding IDE. It takes a really
> well tuned PC to make it worth the processing and memory cost. It's one of
> the main reasons I looked for better PCs... (sadly)
> On this post I wrote about how to debug a python plugin running qgis and
> watching variables and breakpoints from eclipse's pydev.
> http://mauriciodepaulo.blogspot.com/2009/12/pydev-e-qgis.html
> As it's written in portuguese i'm going to explain a bit here.
> You have to call the pydev daemon from your python script and start the
> eclipse debug server.
> Whenever the script is run, it will try to fetch the server and will debug
> it.
> If the server is not on, the script fails.
> Hope it helps.
> Mauricio de Paulo
> 2009/12/30 <luca_manganelli at comune.trento.it>
> Maurício de Paulo <mauricio.dev at gmail.com> scritti il 30/12/2009 05.08.21
>> > Hi Luca,
>> > I've found out how to debug plugins running qgis. I'm going to
>> > report it on my blog in a few days. I'll try to be as clear as
>> > possible with pictures as i'm going to write in portuguese.
>> > Best regards,
>> > Mauricio de Paulo
>> Two issues:
>>  1) autocompletion is *very* slow on a Pentium IV 2,8 Ghz and 1 GB of RAM
>>  2) it doesn't find QT classses and methods
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091230/da976618/attachment-0001.html
