[Qgis-developer] Re: Xcode - compile error, doc questions
Gary Sherman sherman at mrcc.com
Sun Feb 8 19:06:27 EST 2009
On Feb 8, 2009, at 2:41 PM, William Kyngesburye wrote:
> On Feb 8, 2009, at 4:27 PM, Gary Sherman wrote:
>>> For some reason, the north arrow plugin won't compile.  With
>>> moc_plugingui.cpp, plugin.cpp and plugingui.cpp sources I get:
>>> plugingui.h:21: error: expected class-name before '{' token
>> Try adding:
>> #include <QDialog>
>> after the line containing #include "ui_pluginguibase.h"
> No joy.  I thought of that, since it's that way in another plugin's
> plugingui.h.
Odd that it compiles fine outside of Xcode.
>>> - What is help_viewer app needed for?  The "Help Index" from the
>>> Help menu opens said index in Safari.  The pdf userguide is linked
>>> from that index.  If the help_viewer is what is opening Safari,
>>> seems like that should just be done directly by Qgis.
>> It is used to view context help from within the various dialogs in
>> QGIS.
> What is the format of this context help?  I'm just wondering if it
> could also be opened in a web browser, or the system help viewer.
I suppose it could be, sinct the help files are in a simple HTML format.
> Note: just found that the help_viewer in my binary has more of those
> pesky linking issues :(
>>> - A suggestion: have the userguide pdf directly accessible from
>>> the Help menu - saves an application switch.
>>> - I notice that the userguide.pdf is from v0.9.1.  Shouldn't this
>>> have been updated before the 1.0 release?
>> Yes, I noticed this too. The current 1.0 documentation should have
>> been included, something that can't be fixed on the next
>> maintenance release.
> "can" be fixed, you mean?
Right, my fingers type and I have no control over them.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
-Desktop GIS Book:
   *http://desktopgisbook.com
"We work virtually everywhere"
