[Qgis-developer] [Plugin] Added, deleted or changed features in a layer
Olivier Tournaire olitour at gmail.com
Sun Jan 11 11:39:42 EST 2009
OK
2009/1/10 Tim Sutton <tim at linfiniti.com>
> Hi
> 8<-------snip--------------
> > OK, I will attach the patch to ticket #1482 in a few days.
> > Does my proposition in the ticket respect the coding standards ?
> We dont use 'get' get prefix for accessors, so they should be called:
> const QgsFeatureIds?& deletedFeaturesIds() const
> const QgsFeatureList?& addedFeatures() const
> const QgsGeometryMap?& changedGeometries() const
Can I inline the methods or not ?
> Also dont forget the new methods should be added to the corresponding
> sip file so that they appear in python bindings!
OK. Is there only one file to change python/core/sipcoreQgsVectorLayer.cpp ?
> Finally, when you add methods, you should include a doxygen note to
> indicate the method is new to QGIS 1.1 e.g.
> /* Accessor for the list of features pending deletion when the layer is
> next saved.
> * @note this method was added in QGIS 1.1
> * @return const QgsFeatureIds containing the features to be deleted.
Right.
Finally, to make the patch, is it OK with the following command : diff -Naux
original modified > original.patch ?
Is there a special policy for the names of the patch files to attach to the
trac ticket ?
Best regards and sorry for all this boring questions,
Olivier
> Best regards
> Tim
> > Regards,
> > Olivier
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Visit http://linfiniti.com to find out about:
>  * QGIS programming services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting & Support Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
Dr. Olivier Tournaire
MATIS - Institut Géographique National
73, Ave de Paris
94165 St Mandé cedex, France
tel: (+33) 1 43 98 80 00 - 71 25
fax: (+33) 1 43 98 85 81
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090111/760873b6/attachment-0001.html
