[Qgis-developer] link for msys don't work (compile qgis inwindows)
Marco Pasetti pasetti.marco at gmail.com
Tue Jan 20 09:31:31 EST 2009
Hi Alberto,
try to update to 4.4.3
ftp://ftp.trolltech.com/qt/source/qt-win-opensource-4.4.3-mingw.exe
I'm updating the whole build environment in these days. I hope to close the
task as soon as possible.
Regards,
Marco
From: Alberto Asuero Arroyo [mailto:albertoasuero at gmail.com]
Sent: Tuesday, January 20, 2009 3:09 PM
To: Marco Pasetti
Cc: Tim Sutton; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] link for msys don't work (compile qgis
inwindows)
Hi Marco,
I could compile with success but now I'm trying to prepare MS-Windown but
the pythonQT link doesn't work.
I've been looking for the same version (PyQt-win-gpl-4.4.2.zip)  and I found
it, but when I do the make many errors are reported.
"qgis python previous declaration `long int InterlockedCompareExchange"
it's same two libraries who define the same function
any ideas?? thanks!
On Wed, Oct 22, 2008 at 9:17 AM, Marco Pasetti <marcopstt at gmail.com> wrote:
Alberto,
Thanks tim, but it's the file which I had found because there is a problem
with the geos library...
" You're using deprecated header io.h. Please update your sources according
to new layout of GEOS headers and namespace "
The  file install talk about some directories that is not present then I
think it's not the file correct.
I'm going to read the section which godofedro talk about
check out the trunk and read the documentation for MS-Windows
(qgis/ms-windows/README.html)
referring to the above documentation, follow the instruction from point 1 to
9 (included)
Regards,
Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090120/c3be648a/attachment-0001.html
