[Qgis-developer] link for msys don't work (compile qgis inwindows)
Alberto Asuero Arroyo albertoasuero at gmail.com
Thu Jan 22 02:28:13 EST 2009
Hi Marco,
Thank you very much
On Tue, Jan 20, 2009 at 3:31 PM, Marco Pasetti <pasetti.marco at gmail.com>wrote:
>  Hi Alberto,
> try to update to 4.4.3
> ftp://ftp.trolltech.com/qt/source/qt-win-opensource-4.4.3-mingw.exe
> I'm updating the whole build environment in these days. I hope to close the
> task as soon as possible.
> Regards,
> Marco
> *From:* Alberto Asuero Arroyo [mailto:albertoasuero at gmail.com]
> *Sent:* Tuesday, January 20, 2009 3:09 PM
> *To:* Marco Pasetti
> *Cc:* Tim Sutton; qgis-developer at lists.osgeo.org
> *Subject:* Re: [Qgis-developer] link for msys don't work (compile qgis
> inwindows)
> Hi Marco,
> I could compile with success but now I'm trying to prepare MS-Windown but
> the pythonQT link doesn't work.
> I've been looking for the same version (PyQt-win-gpl-4.4.2.zip)  and I
> found it, but when I do the make many errors are reported.
> "qgis python previous declaration `long int InterlockedCompareExchange"
> it's same two libraries who define the same function
> any ideas?? thanks!
> On Wed, Oct 22, 2008 at 9:17 AM, Marco Pasetti <marcopstt at gmail.com>
> wrote:
> Alberto,
> Thanks tim, but it's the file which I had found because there is a problem
> with the geos library...
> " You're using deprecated header io.h. Please update your sources according
> to new layout of GEOS headers and namespace "
> The  file install talk about some directories that is not present then I
> think it's not the file correct.
> I'm going to read the section which godofedro talk about
> check out the trunk and read the documentation for MS-Windows
> (qgis/ms-windows/README.html)
> referring to the above documentation, follow the instruction from point 1
> to 9 (included)
> Regards,
> Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090122/2063191d/attachment.html
