[Qgis-developer] eVis tests
Paolo Cavallini cavallini at faunalia.it
Fri Jul 24 02:12:05 EDT 2009
Hi all.
Running the eVis tutorial
goes smoothly, but when I try to run a query (either by hand or with a preset
query from xml), I get a popup with layer name, x and y (I add a name, select x
and y fields), then:
The layer is not a valid layer and can not be added to the map
The connection seems to be ok:
New Database connection requested...
Connection to [./home/paolo/Desktop/eVis_tutorial/PhotoPoints.db] established
Any explanation? QGIS from trunk on debian unstable.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
