[Qgis-developer] build qgis-grass plugin on Windows
godofredo contreras frdcn at hotmail.com
Mon Mar 23 13:56:01 EDT 2009
If you built your own grass then you can create your msvc import libraries:
Copy and save the following sed script to mkdef.sed in the directory
where your grass dlls are located.
/Dump of file / {
s/Dump of file \([^ ]*\)$/LIBRARY \1/p
a\
EXPORTS
/[ ]*ordinal hint/,/^[ ]*Summary/ {
/^[ ]\+[0-9]\+/ {
s/^[ ]\+[0-9]\+[ ]\+[0-9A-Fa-f]\+[ ]\+[0-9A-Fa-f]\+[ ]\+\([^ =]\+\).*$/ \1/p
Download and install sed utility from:
http://gnuwin32.sourceforge.net/packages/sed.htm
Make sure sed directory is in the environment variable path
Open Visual Studio C++ command line.
change working directory to the directory where your grass dlls are located
Execute the following commands for every grass dll ({grassdll} must be changed to
grass dll name) :
dumpbin /exports {grassdll} | sed -nf mkdef.sed > {grassdll}.def
lib /def:{grassdll}.def /machine:x86
Those commands will create {grassdll}.lib that you can use with
visual studio.
Regards
Godofredo Contreras
> Date: Fri, 20 Mar 2009 20:01:39 +0100
> Subject: Re: [Qgis-developer] build qgis-grass plugin on Windows
> From: giohappy at gmail.com
> To: frdcn at hotmail.com
> CC: qgis-developer at lists.osgeo.org
> > install grass-devel-vc from libs (be sure is the same version that grass )
> This is the problem! I need to recompile qgis-grass plugin for a newer
> version of grass... I wanted to try Marco Pasetti's way [1], but I'm
> not sure how and if it's possible to be integrated in the osgeo4w qgis
> cinfiguration.
> [1] http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html
_________________________________________________________________
Internet Explorer 8 – Now Available. Faster, safer, easier.
http://clk.atdmt.com/MRT/go/141323790/direct/01/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090323/4eef4a4a/attachment.html
