Re [Qgis-developer] compile python bindings with msvc
Tim Sutton lists at linfiniti.com
Thu Nov 12 06:36:26 EST 2009
Sent from my mobile phone.
-----Original Message-----
Date: Thu, 12 Nov 2009 11:33:52
To: Marco Hugentobler<marco at hugis.net>
Subject: Re: [Qgis-developer] compile python bindings with msvc
Hi
You need to compile from in vcexpress launched from an osgeo4w shell. Also need to use cmake advanced options to set python lib etc.
Another option that Juergen was showing me at the hackfest is to compile using his package builder - however the process does not build cleanly for me yet. I have kept some notes on the procedure which I will post to my blog once it is working properly.
Regards
Tim
------Original Message------
Sender: qgis-developer-bounces at lists.osgeo.org
To: QGIS Developer
Subject: [Qgis-developer] compile python bindings with msvc
Sent: Nov 12, 2009 11:08 AM
Hi devs
I'm trying to build the python bindings on windows with msvc, using Qt and the
python classes from OSGEO4W.
cmake tells me that 'PyQt4 development files are missing'. Obviously, the
statement 'from PyQt4 import QtCore, QtGui, QtNetwork, QtSvg, QtXml' in
Python.cmake fails.
Do I need to set an environment variable such that python finds the PyQt4 files?
Or is there a cmake variable that I can set?
Thanks for your help,
Marco
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
