[Qgis-developer] Symbology-NG branch merged
Giovanni Manghi giovanni.manghi at gmail.com
Tue Nov 17 09:19:02 EST 2009
Hi Martin,
really thanks for your effort. Here following I leave feedback after a
little time playing around with the new features. Let me know if you
want me to open tickets.
cheers!
-- Giovanni --
new labels do not appear in the print composer. Then if a zoom is made
in the composer, qgis crashes (both linux and windows)
Warning: QMetaObject::connectSlotsByName: No matching signal for
on_buttonBox_helpRequested()
terminate called after throwing an instance of
'pal::PalException::LayerExists*'
Aborted
label plugin, misses a "apply" button
if I have a color ramp of type "color brewer" made via the style
manager, and I try to make a "graduated" symbology, then qgis crashes
Fatal: ASSERT failure in QList<T>::at: "index out of range",
file /usr/include/qt4/QtCore/qlist.h, line 395
Aborted
in the old symbology, after making a graduated/continuous/unique value
symbology, it is possible to select one or more symbology categories
(using ctrl and/or shift) and change their symbol details
as discussed yesterday in irc chat, it would be nice to have the chance
to import color ramps, in cpt format for example
http://soliton.vm.bytemark.co.uk/pub/cpt-city/
On Mon, 2009-11-16 at 11:47 +0100, Martin Dobias wrote:
> Hi all,
> today I've finally managed to merge my work on symbology and labeling
> in revision r12139.
> Where to look for new features:
> - in Options - Rendering and SVG tab - select Use new generation
> symbology for rendering. Newly loaded layers will use new symbology -
> you'll see different configuation options in vector layer properties
> - in Settings menu there's a Style Manager (the style is saved in
> ~/.qgis/symbology-ng-style.xml)
> - in plugin manager you can find a new plugin "Labeling" which is a
> result of my Summer of Code work
> Regards
> Martin
> Qgis-developer mailing list
