[Qgis-developer] Discussing a forms-builder at the Hackfest
Andreas Neumann a.neumann at carto.net
Sat Oct 17 04:57:43 EDT 2009
good - editing forms with qt-designer and associating the ui-files with
the vector layers would be great.
I added this as a discussion topic at the Hackfest Wiki - looking
forward to the discussion and upcoming solutions to the problem.
Thanks,
Andreas
Jürgen E. Fischer wrote:
> Hi Andreas,
> On Fri, 16. Oct 2009 at 13:34:00 +0200, Andreas Neumann wrote:
>> flexible forms
>> If you think there is room for a discussion on forms at the Hackfest in
>> Vienna, I would make an entry at the Wikipage of the Hackfest.
> +1 from me.
> My idea would be the ability to assign a ui file to each vector layer.
> This could be created using designer (there are also designer classes that
> could probably be integrated into QGIS).  The widgets on the form should be
> named like the attributes and have a type corresponding to the edit type.  That
> form can then be loaded instead of the attribute dialog, but be initialized the
> same.
> We also discussed table joins, which would also fit in there (e.g. load foreign
> keys from a table instead of a value map).
> Jürgen
