[Qgis-developer] QGIS 1.5 freezes at some extent
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Aug 12 02:44:10 EDT 2010
Hi
The reason is most likely that osgeo4w uses a modified qt, patched with the
code from QgsClipper (see http://www.archivum.info/qt-
interest at trolltech.com/2009-09/00028/%5BQt-interest%5D-Modification-for-faster-
coordinate-clipping-in-QOutlineMapper.html).
If you want to have this on Linux too, you might compile qt and replace
src/gui/painting/qoutlinemapper.cpp and .._p.h with the attached files.
Regards,
Marco
Am Donnerstag, 12. August 2010, um 08.06:56 schrieb A. Golubev:
> Hi devs! I`m compile QGIS 1.5.0 with VS2008 with these settings:
> WITH_GRASS:BOOL=0
> WITH_QWT:BOOL=0
> WITH_BINDINGS:BOOL=0
> WITH_POSTGRESQL:BOOL=0
> WITH_INTERNAL_SPATIALITE:BOOL=0
> WITH_SPATIALITE:BOOL=0
> Compile ended successfully, but in some projects (
> http://gis-lab.info/data/osm/arkhan/arkhan.7z ) qgis freezes when
> zooming in. QGIS 1.5.0 from OSGeo4W package open this project fine and
> not freezing in any extent. What can be a reason of this behavior?
> QGIS 1.4 compiled with mingw and similar settings works fine. I`m trying
> GDAL 1.5 and 1.7
> WinXP SP2, Qt 4.6.3
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Webereistrasse 66, 8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
Type: text/x-c++src
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100812/d755ae8a/qoutlinemapper-0001.bin
Type: text/x-chdr
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100812/d755ae8a/qoutlinemapper_p-0001.bin
