[Qgis-developer] QGIS 1.5 freezes at some extent
A. Golubev golubev at nordcomp.ru
Thu Aug 12 03:19:37 EDT 2010
Thanks, Marco!
I`m try to recompile Qt with this patched files.
12.08.2010 10:44, Marco Hugentobler пишет:
> Hi
> The reason is most likely that osgeo4w uses a modified qt, patched with the
> code from QgsClipper (see http://www.archivum.info/qt-
> interest at trolltech.com/2009-09/00028/%5BQt-interest%5D-Modification-for-faster-
> coordinate-clipping-in-QOutlineMapper.html).
> If you want to have this on Linux too, you might compile qt and replace
> src/gui/painting/qoutlinemapper.cpp and .._p.h with the attached files.
> Regards,
> Marco
