[Qgis-developer] The new QGIS plugin repo
Borys Jurgiel borysiasty at gmail.com
Mon Aug 16 05:04:10 EDT 2010
Dnia poniedziałek 16 sierpnia 2010 o 09:08:07 Paolo Cavallini napisał(a):
> Il 15/08/2010 12:47, Borys Jurgiel ha scritto:
> > With Martin we were talking about the GHNS some time ago and it looks
> > promising. The problem is AFAIK there's no admin interface, so probably
> > we can use only the output of it and populate it from the svn.
> > Anyway, Martin is now busy with GSoC, my most time-consuming projects
> > end in October, so unless there's somebody willing to contribute now,
> > the incoming Hackfest is a good oportuinity to get it done.
> I hope someone could start earlier (Jean Roc?), but in any case can you
> mark this as a topic for the hackfest?
Surely, cleaning up the plugin system / gui is my goal for every HF...
Hopefuly this time will be successful.
First step is to investigate what parts of GHNS we can use and how to connect
it to the subversion. Jean Roc, did you take any deeper look into this system?
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100816/7712c5bd/attachment.html
