[Qgis-developer] The new QGIS plugin repo
MORREALE Jean Roc jr.morreale at enoreth.net
Mon Aug 16 12:19:36 EDT 2010
Le 16/08/2010 11:04, Borys Jurgiel a écrit :
> Dnia poniedziałek 16 sierpnia 2010 o 09:08:07 Paolo Cavallini napisał(a):
>> Il 15/08/2010 12:47, Borys Jurgiel ha scritto:
>>> With Martin we were talking about the GHNS some time ago and it looks
>>> promising. The problem is AFAIK there's no admin interface, so probably
>>> we can use only the output of it and populate it from the svn.
>>> Anyway, Martin is now busy with GSoC, my most time-consuming projects
>>> end in October, so unless there's somebody willing to contribute now,
>>> the incoming Hackfest is a good oportuinity to get it done.
>> I hope someone could start earlier (Jean Roc?), but in any case can you
>> mark this as a topic for the hackfest?
> Surely, cleaning up the plugin system / gui is my goal for every HF...
> Hopefuly this time will be successful.
> First step is to investigate what parts of GHNS we can use and how to connect
> it to the subversion. Jean Roc, did you take any deeper look into this system?
Only as an user, I would like to help on this point but unfortunately I
can't as I'm not a dev (which is my aim for the HF2012 ;) ).
