[Qgis-developer] Remove geoprocessing plugin?
Martin Dobias wonder.sk at gmail.com
Mon Dec 13 15:05:29 EST 2010
Hi Tim
On Mon, Dec 13, 2010 at 10:06 AM, Tim Sutton <lists at linfiniti.com> wrote:
> +1
> And other candidates to recieve the axe:
>  - quickprint
I would vote to remove it once we have some print composer templates:
so that people can print / export to pdf with no effort to lay out the
items.
>  - copyright (you can just add an annotation)
IIRC annotations are always bound to a particular position on map, so
they're a bit different than the copyright label that is always in the
corner...
Cheers
Martin
