[Qgis-developer] Selection: new simbology vs old symbology
luca_manganelli at comune.trento.it
Wed Mar 3 10:23:03 EST 2010
I discovered that this happens:
given a linestring layer, and I set simbology to line width 3. Then, if I
select one feature:
- old symbology: the selection has the same width, 3.
- new symbology: the selection has always width 1. It seems that it ignores
the new symbology settings.
The same problem happens on point layers, if you use SVG symbols: when you
select one point, no selection appears. So, it's difficult to identify
which features are selected...
