[Qgis-user] Re: [Qgis-developer] announcing DPSimplify
Alexander Bruy alexander.bruy at gmail.com
Fri Mar 5 07:44:28 EST 2010
Hi guys,
thanks for feedback and discussion.
DPSimplify was developed for one of GIS-Lab projects. There is some problems
with standart tool and Maxim ask me to write plugin with some
additional features.
2010/3/5 Richard Duivenvoorde <rdmailings at duif.net>:
> - DPSimplify actually simplifies your data on the fly, and gives you the
> option to either save it to a new shapefile or not (nice !)
> - DPSimplify also reports the number of vertices reduced, which gives you
> the option to lower or higher your tolerance (nice)
We need this features in our project and I hope this can be usefull for other
users
> - DPSimplify seems to  work only with line and polygons data (not multi* )?
> (at first there was no layer in the dropdown, untill I added a (non
> multi)polygon layer)
We develop this plugin first or all for simplifing lines (a lot of
lines). Polygon
simplification is in TODO list. MultiLines are not supported yet.
> - DPSimplify the about-box raises an python exception here
I'll look on this tonight and try to fix
> And to make myself clear: I do not want to discourage Alexander to develop
> the plugin!! Because if I'm correct, the current vector-menu stuff is
> actually cpp ported from the former python plugin as well.
To make clear :-): we develop this plugin for our project and then share it with
community. As I see, maybe it will be better to integrate DPSimplify
into fTools.
Sorry for long reply
Alexander Bruy
