[Qgis-developer] request for review: Add possibility to ignore
geotransform/gcps in QgsRasterLayer
Manuel Massing
m.massing at warped-space.de
Fri May 7 08:30:00 EDT 2010
Hello,
I am currently fixing a problem with the georeferencer, which does
not handle files with existing georeferencing information correctly
(see #2465 - https://trac.osgeo.org/qgis/ticket/2465).
To this end, I'd like to add functionality which allows one to override the
gdal geotransform in QgsRasterLayer, but as this touches on a core class I'd
appreciate if someone could have a look and sign off or comment on the
proposed patch.
Essentially, the patch adds a constructor and flags which allow one to
ignore ground control point and geotransform information when constructing the
QgsRasterLayer.
Okay to commit? I'll add an appropriate unit test if accepted.
thanks & best regards,
Manuel
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100507/063368da/qgsrasterlayer_ignore_geotransform.bin
