[Qgis-developer] problems with SDA4PP plugin
Giovanni Manghi giovanni.manghi at gmail.com
Mon May 17 09:57:02 EDT 2010
> SDA4PP uses only rpy2. I never tried under osgeo4w. But theoretically,
> as Carson said, the plugin should also run under osgeo4w, if required
> R packages are installed and the path of R is defined correctly.
> if it is tried, is there any error?
I tried but it doesn't seems to work. It always says that rgdal is
missing, but R/rpy2/rgdal/etc. are correctly installed as the Home Range
plugin (that uses R/rpy2/rgdal/etc.) is working fine.
cheers
-- Giovanni --
