[Qgis-developer] Request for QGIS Trac RSS
Pirmin Kalberer pi_ml at sourcepole.com
Mon Nov 29 03:27:37 EST 2010
Hi Leonhard,
The trac RSS feed is enabled by default:
https://trac.osgeo.org/qgis/timeline?format=rss
You can configure the feed on https://trac.osgeo.org/qgis/timeline
Pirmin
Am Sonntag, 28. November 2010, um 23.50:18 schrieb William Kyngesburye:
> Note that the commit mailing list has a size cap - if a commit goes over
> the limit (ie adding a whole new plugin), it doesn't get sent to the list.
> On Nov 28, 2010, at 3:39 PM, Alex Mandel wrote:
> > On 11/28/2010 11:57 AM, Jürgen E. Fischer wrote:
> >> Hi Leonhard,
> >> On Sun, 28. Nov 2010 at 19:38:26 +0100, Leonhard Weber wrote:
> >>> Wanted to ask if it would be possible to enable RSS for the
> >>> SourceBrowser in your Trac, maybe not only for the SourceBrowser? (my
> >>> main interest for now is with the SourceBrowser, but maybe there are
> >>> others that want to also watch the tickets).
> >> I don't know what's needed for RSS, but there are trac[1] and commit[2]
> >> mailing lists.
> >> Jürgen
> >> [1] http://lists.osgeo.org/mailman/listinfo/qgis-trac
> >> [2] http://lists.osgeo.org/mailman/listinfo/qgis-commit
> > Can you point us to a site that has an RSS on the SourceBrowser? I'm a
> > little confused about how it would be useful. As Jürgen mentioned it
> > sounds like the commit mailing list would offer the same service.
> > Thanks,
> > Alex
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
> [Marvin]  You think you have problems?  What are you supposed to do if you
> ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000
> times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
