[Qgis-developer] converting to GPX fails
Paolo Cavallini cavallini at faunalia.it
Sat Oct 16 01:59:32 EDT 2010
Hi all.
Converting (right click->Save as...) a shp in gpx results in an error:
creation of field DATA_INI failed (OGR error: Field of name 'DATA_INI' is not
supported in GPX schema. Use GPX_USE_EXTENSIONS creation option to allow use of the
<extensions> element.)
The field 'DATA_INI' is valid in DBF, what can we do about this?
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
