[Qgis-developer] slow raster loading
Giovanni Manghi giovanni.manghi at gmail.com
Sat Aug 13 15:19:24 EDT 2011
Hi Tim,
> They should be.
> Try going to the histogram tab of your raster properties or do
> something else that requires stats. In many cases, stats are not
> needed so you may not be seeing thm gathered. Also for read only
> medai, the stats should land up in the proxy dir which is set to
> ~/.qgis/gdal_pam. Otherwise can you give me a specific procedure to
> follow to replicate?
sorry for the noise, yes it works ok.
Cheers
-- Giovanni --
