[Qgis-developer] checkbox table widget writing on the left column
Paolo Cavallini cavallini at faunalia.it
Wed Dec 21 05:03:30 EST 2011
Il 21/12/2011 10:45, Giovanni Manghi ha scritto:
>> I confirm: checkboxes and value map do not work proprerly. Values
>> inserted are not show correctly, even if they are written.
> Are you using a docked table of attributes?
> I found that strange things happen when the table is docked...
non docked
thanks
also, I confirm the problem with field calc filling up with NULLs
instead of calculation results
Paolo Cavallini
See: http://www.faunalia.it/pc
