[Qgis-developer] checkbox table widget writing on the left column
Ramon Andiñach custard at westnet.com.au
Wed Dec 21 16:37:10 EST 2011
On 21/12/2011, at 17:45 , Giovanni Manghi wrote:
>> I confirm: checkboxes and value map do not work proprerly. Values
>> inserted are not show correctly, even if they are written.
> Are you using a docked table of attributes?
> I found that strange things happen when the table is docked...
> cheers
> -- Giovanni --
For me, it's if the attributes are open (and not just docked) while I'm editing the layer. Then it's very likely that the rows/objects that are edited and unsaved will display strangely.
-ramon.
