[Qgis-developer] QGIS GDAL/OGR Version
Jürgen E. Fischer
jef at norbit.de
Sat Jan 8 10:19:59 EST 2011
Hi B.,
On Sat, 08. Jan 2011 at 08:28:13 -0500, b.edwards at ville.laval.qc.ca wrote:
> Upon installing QGIS 1.6 via the standalone installer, I noticed that the
> GDAL/OGR version varies among the
> 1) QGIS GDAL/OGR Build Version - Listed under Help>About>About
> 2) OGR Data Provider - Listed under Help>About>Providers
> 3) OGR Layer Converter Plugin - I was unable to find any information
> regarding the OGR version it was built/compiled against
That's all using GDAL 1.7. The output in the about box is wrong (should be fixed
in the nightly build).
> I also noticed that in the installation files there are system files
> referring to both GDAL 1.6 and GDAL 1.7; however I am only able to run GDAL
> 1.5 via command line (called from C:\Program Files\Quantum GIS Copiapo\bin).
You need to run "gdal17" to switch to GDAL 1.7 on the command line.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
