[Qgis-developer] Re: Raster providers
John C. Tull jctull at gmail.com
Wed Jan 12 22:53:21 EST 2011
Hi Radim,
I tried building today on OS X. The build failed with the following output:
[ 20%] Building CXX object src/analysis/CMakeFiles/qgis_analysis.dir/qgsrastercalcparser.cpp.o
Linking CXX shared library libqgis_analysis.dylib
[ 20%] Built target qgis_analysis
[ 20%] Generating analysis/sipanalysispart0.cpp, analysis/sipanalysispart1.cpp, analysis/sipanalysispart2.cpp, analysis/sipanalysispart3.cpp
sip: /Users/jctull/sources/qgis/raster-providers/python/core/conversions.sip:326: %MappedType template for this type has already been defined
make[2]: *** [python/analysis/sipanalysispart0.cpp] Error 1
make[1]: *** [python/CMakeFiles/python_module_qgis_analysis.dir/all] Error 2
make: *** [all] Error 2
I have no such problem building from a fresh copy of qgis trunk.
Regards,
John
On Jan 8, 2011, at 11:26 AM, Radim Blazek wrote:
> Hi all,
> new raster providers are ready for testing. The work is not yet
> finished but all the old functionality should be available. Current
> status:
> - GDAL: on-the-fly reprojection via gdal warp, quite slow, I have not
> yet implemented the trick used in Mapserver Marco pointed me to.
> Please let me know, if you consider the speed at least acceptable for
> real work. The speed depends especially on output display size.
> - GRASS: all the old functionality is back, the data are provided
> instead of just a picture so that it is possible to assign a style in
> QGIS like it was possible with GRASS via GDAL, reprojection is not yet
> implemented
> - WMS: should work like before, the requested SRS does not yet follow
> current project projection
> Please test the raster providers branch and let me know about problems:
> svn co https://svn.osgeo.org/qgis/branches/raster-providers
> I would like to merge the branch to trunk and continue the work in trunk.
> Radim
> Qgis-developer mailing list
