[Qgis-developer] Re: Raster providers
Radim Blazek radim.blazek at gmail.com
Thu Jan 13 02:49:08 EST 2011
Hi, thanks for testing.
Unfortunately I have no idea. QSet is not used in the code I touched.
I don't know much about Python bindings.
python/core/conversions.sip is generated somehow automaticaly?
Does it need to updated?
Radim
On Thu, Jan 13, 2011 at 4:53 AM, John C. Tull <jctull at gmail.com> wrote:
> Hi Radim,
> I tried building today on OS X. The build failed with the following output:
> [ 20%] Building CXX object src/analysis/CMakeFiles/qgis_analysis.dir/qgsrastercalcparser.cpp.o
> Linking CXX shared library libqgis_analysis.dylib
> [ 20%] Built target qgis_analysis
> [ 20%] Generating analysis/sipanalysispart0.cpp, analysis/sipanalysispart1.cpp, analysis/sipanalysispart2.cpp, analysis/sipanalysispart3.cpp
> sip: /Users/jctull/sources/qgis/raster-providers/python/core/conversions.sip:326: %MappedType template for this type has already been defined
> make[2]: *** [python/analysis/sipanalysispart0.cpp] Error 1
> make[1]: *** [python/CMakeFiles/python_module_qgis_analysis.dir/all] Error 2
> make: *** [all] Error 2
> I have no such problem building from a fresh copy of qgis trunk.
> Regards,
> John
> On Jan 8, 2011, at 11:26 AM, Radim Blazek wrote:
>> Hi all,
>> new raster providers are ready for testing. The work is not yet
>> finished but all the old functionality should be available. Current
>> status:
>> - GDAL: on-the-fly reprojection via gdal warp, quite slow, I have not
>> yet implemented the trick used in Mapserver Marco pointed me to.
>> Please let me know, if you consider the speed at least acceptable for
>> real work. The speed depends especially on output display size.
>> - GRASS: all the old functionality is back, the data are provided
>> instead of just a picture so that it is possible to assign a style in
>> QGIS like it was possible with GRASS via GDAL, reprojection is not yet
>> implemented
>> - WMS: should work like before, the requested SRS does not yet follow
>> current project projection
>> Please test the raster providers branch and let me know about problems:
>> svn co https://svn.osgeo.org/qgis/branches/raster-providers
>> I would like to merge the branch to trunk and continue the work in trunk.
>> Radim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
