[Qgis-developer] macosx dialog issues
    John C. Tull
    jctull at gmail.com
    Sat Mar  5 15:56:46 EST 2011
Hi Carson,
On Mar 5, 2011, at 11:28 AM, Carson Farmer wrote:
> Hi John, I believ José had problems with:
> - Geoprocessing tools available as Intersect two layers
Works for me.
> - Data management tools as Export to projection
Also works fine for me.
>> The only problem I had was with Merge Shapefiles. If I tick the 'Select by layers in the folder', I cannot choose a folder in the dialog. The Ok button never becomes available when trying to select a folder. I can select a shapefile and the OK button is available. I might be misunderstanding what this option is intended to do. When turning it off, I can select a folder, but the tool crashed qgis. This was because my folder had mixed geometry types. See output below. I suppose this crash should be avoided somehow.
> Hmm, ok I'll look into this one, thanks for the update.
I hope it is easily solved.
>> One random thought arose as I tested the tools. Why is the random select tool limited to 30 features?
> What? It shouldn't be? Unless your layer only has 30 features?
Ok, tested again and it worked fine. I must have been working on a layer with only 30 features and did not make the connection there. It works as it should.
Cheers,
John
