[Qgis-developer] Lost settings for Line Decoration options
Andrea Peri aperi2007 at gmail.com
Mon Oct 3 15:05:00 EDT 2011
Hi Martin,
thx for your response.
Yopu are reason,
more probably I confuse the LineDecoration with the MarkerLine.
In effect the marker-line give all the option of line-decoration.
Sorry for noise.
However I aggre with the option to deprecated  the "LineDecoration"
rendering.
Actually an user could use it (linedecoration) in some styles , instead of a
more useful and powerful "marker-line"
regards,
2011/10/3 Martin Dobias <wonder.sk at gmail.com>
> On Mon, Oct 3, 2011 at 11:02 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > I notice the lasts versions of qgis-dev and also the qgis 1.7.x
> > has lost some settings for the lines in the new symbology.Infact actually
> if
> > is choose the option
> > "line decoration" is available only color and size.
> > Instead before was able to choose the offset horizontal and vertical and
> > also
> > was available the choos of many symbols.
> > Not the symbol is only the "right arrow".
> I believe you has been using "marker line" symbol layer with the
> option to render the marker at the start/end of the polyline. In
> contrast "line decoration" always used to be this simple. Given that
> "marker line" has superior functionality we will probably remove "line
> decoration" completely in future.
> Martin
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111003/411933aa/attachment.html
