[Qgis-developer] WPS plugin not connecting (proxy?)
Horst Duester horst.duester at kappasys.ch
Fri Oct 14 11:02:04 EDT 2011
Hi Paolo
Yes you are right. The WPS-Client isnt able to connect through proxy. I plan to extend the plugin at the hackfest
Regards from Lüderitz/Namibia
Horst
Dr. Horst Düster
Am 14.10.2011 um 14:24 schrieb Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> I set up the proxy in qgis, and everything is working, except for the
> Elevation plugin (as I already wrote) and WPS plugin: do they both use
> another method for accessing the web, bypassing the proxy setting?
> All the best.
> http://faunalia.it/pc
> Qgis-developer mailing list
