[Qgis-developer] 2 versions of Processing Framework Manager
Agustin Lobo alobolistas at gmail.com
Wed Oct 19 02:05:01 EDT 2011
I see 2 versions of Processing Framework Manager,
the 0.26 installs fine on 1.7.1 (ubuntu 10.04 LTS binaries from
ubuntugis-unstable)
but the 0.21 issues this error:
Couldn't load plugin saga due an error when calling its classFactory() method
  File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 138, in
startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/home/alobo/.qgis/python/plugins/saga/__init__.py", line 76,
in classFactory
    from plugin import SAGAPlugin
  File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 283, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/home/alobo/.qgis/python/plugins/saga/plugin.py", line 31, in
    import processingmanager.processing as processing
ImportError: No module named processingmanager.processing
I assume I just have to uninstall 0.21 (the plugin gets installed
despite the error, which is unusual)
Agus
