[Qgis-developer] Re: [Qgis-user] 2 versions of Processing Framework Manager
Julien Malik julien.malik at c-s.fr
Wed Oct 19 05:52:40 EDT 2011
Hello Agus,
The version to use is of course the last one : 0.26.
I don't see several versions in the plugin installer.
The directory in which the 'Processing Framework Manager' is installed
has been renamed recently, from processingplugin to processingmanager.
This may be the root of the problem.
Can you double-check your $HOME/.qgis/python/plugins directory ?
After installing the 0.26 version, you should not see any directory
named "processingplugin". Just "processingmanager".
If so, maybe just deleting it will make the 0.21 reference go away.
Julien
Le 19/10/2011 08:05, Agustin Lobo a écrit :
> I see 2 versions of Processing Framework Manager,
> the 0.26 installs fine on 1.7.1 (ubuntu 10.04 LTS binaries from
> ubuntugis-unstable)
> but the 0.21 issues this error:
> Couldn't load plugin saga due an error when calling its classFactory() method
> Traceback (most recent call last):
>    File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 138, in
> startPlugin
>      plugins[packageName] = package.classFactory(iface)
>    File "/home/alobo/.qgis/python/plugins/saga/__init__.py", line 76,
> in classFactory
>      from plugin import SAGAPlugin
>    File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 283, in _import
>      mod = _builtin_import(name, globals, locals, fromlist, level)
>    File "/home/alobo/.qgis/python/plugins/saga/plugin.py", line 31, in
>      import processingmanager.processing as processing
> ImportError: No module named processingmanager.processing
> I assume I just have to uninstall 0.21 (the plugin gets installed
> despite the error, which is unusual)
> Agus
> Qgis-user mailing list
