[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Christopher Stark christopherstark at gmx.de
Wed Oct 19 04:08:28 EDT 2011
Hi Noli,
which parts in this code do I have to modify for my Qgis Server Project?
I pasted this code into a html (index2.html) file within var/www/  but
there is nothing displayed when I open
localhost/index2.html
best regards
Christopher
Am 16.10.2011 04:40, schrieb Noli Sicad:
>> The most common web client being Openlayers, this will require work on
>> your part, mainly a few lines of javascript in a web page. You might be
>> able to use it directly in Geocommons or in Mapfish (also takes setup).
> This is how Tim used it for OpenLayers client (below).
> Very few documentation how to actually use in OpenLayers and WMS.
> Noli
> <script type="text/javascript">
>         var map, layer;
>         function init(){
>           var MapOptions = {
>             projection: new OpenLayers.Projection("EPSG:32633"),
>             units: "m",
>             masxScale: 19567.879237500,
>             //maxScale:1000,
>             //minScale:17000000,
>             numZoomLevels: 10,
>             resolutions: [19567.8792375, 9783.93961875,
> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
> 305.7481130859375, 152.87405654296876, 76.43702827148438,
> 38.21851413574219],
>             maxExtent: new
> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>             fractionalZoom: false,
>             transitionEffect:"resize",
>           map = new OpenLayers.Map( 'map', MapOptions );
>           layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>               "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>               {layers: 'utno-test'} );
>           map.addLayer(layer);
>           map.zoomToMaxExtent();
>     </script>
>   </head>
>   <body onload="init()">
>     <div id="map" class="map"></div>
>   </body>
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111019/461e5006/attachment-0001.html
