[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Noli Sicad nsicad at gmail.com
Wed Oct 19 04:30:06 EDT 2011
Hi Christopher,
The code that I posted is not complete.
Did you include OpenLayers.js and CSS for the openlayers?
Visit this link and to see the whole code,
http://linfiniti.com/2011/09/qgis-server-with-tilecache/
It seem the link is not working now. However, you browse the any
openlayers example and see how the post that I copied from Tim's is
used.
Noli
On 10/19/11, Christopher Stark <christopherstark at gmx.de> wrote:
> Hi Noli,
> which parts in this code do I have to modify for my Qgis Server Project?
> I pasted this code into a html (index2.html) file within var/www/  but
> there is nothing displayed when I open
> localhost/index2.html
> best regards
> Christopher
> Am 16.10.2011 04:40, schrieb Noli Sicad:
>>> The most common web client being Openlayers, this will require work on
>>> your part, mainly a few lines of javascript in a web page. You might be
>>> able to use it directly in Geocommons or in Mapfish (also takes setup).
>> This is how Tim used it for OpenLayers client (below).
>> Very few documentation how to actually use in OpenLayers and WMS.
>> Noli
>> <script type="text/javascript">
>>         var map, layer;
>>         function init(){
>>           var MapOptions = {
>>             projection: new OpenLayers.Projection("EPSG:32633"),
>>             units: "m",
>>             masxScale: 19567.879237500,
>>             //maxScale:1000,
>>             //minScale:17000000,
>>             numZoomLevels: 10,
>>             resolutions: [19567.8792375, 9783.93961875,
>> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
>> 305.7481130859375, 152.87405654296876, 76.43702827148438,
>> 38.21851413574219],
>>             maxExtent: new
>> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>>             fractionalZoom: false,
>>             transitionEffect:"resize",
>>           map = new OpenLayers.Map( 'map', MapOptions );
>>           layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>               "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>>               {layers: 'utno-test'} );
>>           map.addLayer(layer);
>>           map.zoomToMaxExtent();
>>     </script>
>>   </head>
>>   <body onload="init()">
>>     <div id="map" class="map"></div>
>>   </body>
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
