[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Noli Sicad nsicad at gmail.com
Wed Oct 19 04:39:25 EDT 2011
I guess you have read this,
http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/
Noli
On 10/19/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Christopher,
> The code that I posted is not complete.
> Did you include OpenLayers.js and CSS for the openlayers?
> Visit this link and to see the whole code,
> http://linfiniti.com/2011/09/qgis-server-with-tilecache/
> It seem the link is not working now. However, you browse the any
> openlayers example and see how the post that I copied from Tim's is
> used.
> Noli
> On 10/19/11, Christopher Stark <christopherstark at gmx.de> wrote:
>> Hi Noli,
>> which parts in this code do I have to modify for my Qgis Server Project?
>> I pasted this code into a html (index2.html) file within var/www/  but
>> there is nothing displayed when I open
>> localhost/index2.html
>> best regards
>> Christopher
>> Am 16.10.2011 04:40, schrieb Noli Sicad:
>>>> The most common web client being Openlayers, this will require work on
>>>> your part, mainly a few lines of javascript in a web page. You might be
>>>> able to use it directly in Geocommons or in Mapfish (also takes setup).
>>> This is how Tim used it for OpenLayers client (below).
>>> Very few documentation how to actually use in OpenLayers and WMS.
>>> Noli
>>> <script type="text/javascript">
>>>         var map, layer;
>>>         function init(){
>>>           var MapOptions = {
>>>             projection: new OpenLayers.Projection("EPSG:32633"),
>>>             units: "m",
>>>             masxScale: 19567.879237500,
>>>             //maxScale:1000,
>>>             //minScale:17000000,
>>>             numZoomLevels: 10,
>>>             resolutions: [19567.8792375, 9783.93961875,
>>> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
>>> 305.7481130859375, 152.87405654296876, 76.43702827148438,
>>> 38.21851413574219],
>>>             maxExtent: new
>>> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>>>             fractionalZoom: false,
>>>             transitionEffect:"resize",
>>>           map = new OpenLayers.Map( 'map', MapOptions );
>>>           layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>>               "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>>>               {layers: 'utno-test'} );
>>>           map.addLayer(layer);
>>>           map.zoomToMaxExtent();
>>>     </script>
>>>   </head>
>>>   <body onload="init()">
>>>     <div id="map" class="map"></div>
>>>   </body>
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
