[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Christopher Stark christopherstark at gmx.de
Wed Oct 19 06:21:19 EDT 2011
Hi Noli,
Thanks, I did this and came to this point:
*sudo cp /home/timlinux/dev/cpp/qgis/src/mapserver/wms_metadata.xml .
Now edit that file and set your details as appopriate.
Which would be "appropriate details" for me?
best regards
Christopher
Am 19.10.2011 10:39, schrieb Noli Sicad:
> I guess you have read this,
> http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/
> Noli
> On 10/19/11, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Christopher,
>> The code that I posted is not complete.
>> Did you include OpenLayers.js and CSS for the openlayers?
>> Visit this link and to see the whole code,
>> http://linfiniti.com/2011/09/qgis-server-with-tilecache/
>> It seem the link is not working now. However, you browse the any
>> openlayers example and see how the post that I copied from Tim's is
>> used.
>> Noli
>> On 10/19/11, Christopher Stark <christopherstark at gmx.de> wrote:
>>> Hi Noli,
>>> which parts in this code do I have to modify for my Qgis Server Project?
>>> I pasted this code into a html (index2.html) file within var/www/  but
>>> there is nothing displayed when I open
>>> localhost/index2.html
>>> best regards
>>> Christopher
>>> Am 16.10.2011 04:40, schrieb Noli Sicad:
>>>>> The most common web client being Openlayers, this will require work on
>>>>> your part, mainly a few lines of javascript in a web page. You might be
>>>>> able to use it directly in Geocommons or in Mapfish (also takes setup).
>>>> This is how Tim used it for OpenLayers client (below).
>>>> Very few documentation how to actually use in OpenLayers and WMS.
>>>> Noli
>>>> <script type="text/javascript">
>>>>         var map, layer;
>>>>         function init(){
>>>>           var MapOptions = {
>>>>             projection: new OpenLayers.Projection("EPSG:32633"),
>>>>             units: "m",
>>>>             masxScale: 19567.879237500,
>>>>             //maxScale:1000,
>>>>             //minScale:17000000,
>>>>             numZoomLevels: 10,
>>>>             resolutions: [19567.8792375, 9783.93961875,
>>>> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
>>>> 305.7481130859375, 152.87405654296876, 76.43702827148438,
>>>> 38.21851413574219],
>>>>             maxExtent: new
>>>> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>>>>             fractionalZoom: false,
>>>>             transitionEffect:"resize",
>>>>           map = new OpenLayers.Map( 'map', MapOptions );
>>>>           layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>>>               "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>>>>               {layers: 'utno-test'} );
>>>>           map.addLayer(layer);
>>>>           map.zoomToMaxExtent();
>>>>     </script>
>>>>   </head>
>>>>   <body onload="init()">
>>>>     <div id="map" class="map"></div>
>>>>   </body>
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111019/21c7ea02/attachment-0001.html
