[Qgis-developer] various problems during a course
Paolo Cavallini cavallini at faunalia.it
Wed Oct 19 05:08:04 EDT 2011
Il 19/10/2011 01:36, Giovanni Manghi ha scritto:
> io ho bisogno di un crash course su come mettere su un webgis basato su
> qgis-server con questo framework.
> da dove parto?
> PS
> é urgente
suggerimento: concordaci un compenso e datevi un appuntamento
(chat+tel), altrimenti e' difficile che tu ci cavi qualcosa ;)
Paolo Cavallini
See: http://www.faunalia.it/pc
> Hi all.
> Today, during a course, I spotted several problems:
> - the plugin Elevation does not take into account the proxy setting, so
> it does not work (known problem[0]) and it locks QGIS, forcing a
> restart; I suggest to fix it or, if impossible, to deprecate it
> - opening a
> - the plugin CSW client does not connect (I'm behind a proxy, do not
> know what's going wrong) with error:
> Error connecting to server geocat.ch: [same for others]
> <urlopen error timed out>
> - the tile scale apparently does not work
> - invert color map (in raster properties) option seem bugged: the flag
> is unchecked when closing the window
> - Rasterlite layers, e.g.
> http://download.gfoss.it/TrueMarble/TrueMarble-2km.sqlite
> are extremely slow to open (I remember a while ago they were
> surprisingly fast); I noticed it uses only one CPU out of four, BTW
> Feedback welcome.
> [0]https://trac.faunalia.it/qgis_plugins/ticket/18
Hi all.
More minor issues:
- if I edit label properties with the button (close to rotate label),
the label disappears
- the random colour ramps are generally ugly, and often colours are repeated
- a button "Randomize" is missin for random colour ramps (currently one
has to change the number of classes to have a new ramp)
- in the editing widgets, the slider does not work
- the measure area tool seems to be wrong when started with the
ellipsoid off (measures are doubled); switching ellipsoid on and off
again brings back the good value.
If I get confirmations of the above I'll open tickets (but will not mind
if someone else will do it sooner).
Thanks.
Paolo Cavallini
