[Qgis-developer] "value tool" missing from the contributed repo
Richard Duivenvoorde rdmailings at duif.net
Fri Oct 21 05:09:42 EDT 2011
On 2011-10-21 10:42, Alexander Bruy wrote:
> Hi Giovanni,
> maybe this is related to syntax error in repository xml file [0]
> [0] http://osgeo-org.1803224.n2.nabble.com/Syntax-error-in-User-Contributed-repo-xml-td6912258.html
> 2011/10/21 Giovanni Manghi <giovanni.manghi at gmail.com>:
>>> maybe Gary has an idea why it does not show up in the xml-feed anymore?
>> I have also the "table manager" plugin installed that shows as orphan,
>> maybe it is related?
Hi Alexander,
good catch I think :-)
Either Fidel or Rodrigo (in bcc), can you please remove the &-sign from
the contributor string at http://pyqgis.org/admin/contributed/?page=9
Apparently the script which generates the xml-feed does not escape that
for &amp; and qgis is chocking on that?
Or Gary can try to escape the &-signs?
Regards,
R
