[Qgis-developer] "value tool" missing from the contributed repo
Alessandro Pasotti apasotti at gmail.com
Fri Oct 21 05:14:56 EDT 2011
2011/10/21 Richard Duivenvoorde <rdmailings at duif.net>
> On 2011-10-21 10:42, Alexander Bruy wrote:
> > Hi Giovanni,
> > maybe this is related to syntax error in repository xml file [0]
> > [0]
> http://osgeo-org.1803224.n2.nabble.com/Syntax-error-in-User-Contributed-repo-xml-td6912258.html
> > 2011/10/21 Giovanni Manghi <giovanni.manghi at gmail.com>:
> >>> maybe Gary has an idea why it does not show up in the xml-feed anymore?
> >> I have also the "table manager" plugin installed that shows as orphan,
> >> maybe it is related?
> Hi Alexander,
> good catch I think :-)
> Either Fidel or Rodrigo (in bcc), can you please remove the &-sign from
> the contributor string at http://pyqgis.org/admin/contributed/?page=9
> Apparently the script which generates the xml-feed does not escape that
> for &amp; and qgis is chocking on that?
> Or Gary can try to escape the &-signs?
> Regards,
> R
> Qgis-developer mailing list
Hi Richard,
can you please check that the same problem does not exists in the new
repository ?
I'm pretty sure that it should be fine with entities, but just in case.
Thanks.
Alessandro Pasotti
w3:   www.itopen.it
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111021/196d25ab/attachment.html
