[Qgis-developer] Re: QGIS 1.7.0.1, eVis plugin using Sqlite / Spatialite and Mac OS X
Noli Sicad nsicad at gmail.com
Fri Oct 28 03:33:50 EDT 2011
Which version of QGIS and platform has support for Qt sqlite driver
(i.e. QSQLITE)?
http://doc.qt.nokia.com/stable/sql-driver.html#qsqlite
Noli
On 10/28/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> It seems that it needs - qsqlite.
>   else if ( QSQLITE == databaseType( ) && !mDatabase.contains( "sqlite" ) )
>     mDatabase = QSqlDatabase::addDatabase( "QSQLITE", "sqlite" );
>   else if ( QSQLITE == databaseType( ) )
>     mDatabase = QSqlDatabase::database( "sqlite" );
>   else
>     setLastError( "No matching DATABASE_TYPE found" );
>     return false;
> https://svn.osgeo.org/qgis/trunk/qgis/src/plugins/evis/databaseconnection/evisdatabaseconnection.cpp
> Now, how can we install qsqlite driver in Mac OS X?
> Noli
>> Hi,
>> What needs to be installed to make eVis plugin works with spatialite
>> db in Mac OS X?
>> The author mentioned about Qt library.
>> "... Qt's library so you don't have to have spatialite."
>> http://osgeo-org.1803224.n2.nabble.com/Qgis-and-sqlite-td4521419.html
>> eVis is now default plugin in QGIS 1.7.x and QGIS 1.8.0.
>> I got this error using spatialite db.
>> New Database connection requested...
>> Connection to
>> [./Volumes/MAC_OS_1068/Work/work_d1/Work_11/SImon_GPS_Photos/GPS_Photo.db]
>> failed: Driver not loaded Driver not loaded
>> Is eVis plugin sqlite/spatialite working in Linux?
>> Any experience how to hack this to read my db?
>> Thanks.
>> Noli
