[Qgis-developer] QGIS 1.7.0.1, eVis plugin using Sqlite / Spatialite and Mac OS X
William Kyngesburye woklist at kyngchaos.com
Fri Oct 28 09:44:59 EDT 2011
I'll add it to my list of Qt extras to bundle in the app.  Since it's a requirement, I'll try to get an update out this weekend.
You could install it yourself, but it's tricky - you don't want to install Qt and copy qsqlite into Qgis, it'll still reference the now-installed Qt and cause Qgis to crash because of multiple loaded Qt's.  Pacifist would allow you to extract qsqlite without installing all of Qt.
On Oct 28, 2011, at 2:33 AM, Noli Sicad wrote:
> Which version of QGIS and platform has support for Qt sqlite driver
> (i.e. QSQLITE)?
> http://doc.qt.nokia.com/stable/sql-driver.html#qsqlite
> Noli
> On 10/28/11, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi,
>> It seems that it needs - qsqlite.
>>  else if ( QSQLITE == databaseType( ) && !mDatabase.contains( "sqlite" ) )
>>    mDatabase = QSqlDatabase::addDatabase( "QSQLITE", "sqlite" );
>>  else if ( QSQLITE == databaseType( ) )
>>    mDatabase = QSqlDatabase::database( "sqlite" );
>>  else
>>    setLastError( "No matching DATABASE_TYPE found" );
>>    return false;
>> https://svn.osgeo.org/qgis/trunk/qgis/src/plugins/evis/databaseconnection/evisdatabaseconnection.cpp
>> Now, how can we install qsqlite driver in Mac OS X?
>> Noli
>>> Hi,
>>> What needs to be installed to make eVis plugin works with spatialite
>>> db in Mac OS X?
>>> The author mentioned about Qt library.
>>> "... Qt's library so you don't have to have spatialite."
>>> http://osgeo-org.1803224.n2.nabble.com/Qgis-and-sqlite-td4521419.html
>>> eVis is now default plugin in QGIS 1.7.x and QGIS 1.8.0.
>>> I got this error using spatialite db.
>>> New Database connection requested...
>>> Connection to
>>> [./Volumes/MAC_OS_1068/Work/work_d1/Work_11/SImon_GPS_Photos/GPS_Photo.db]
>>> failed: Driver not loaded Driver not loaded
>>> Is eVis plugin sqlite/spatialite working in Linux?
>>> Any experience how to hack this to read my db?
>>> Thanks.
>>> Noli
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
