[Qgis-developer] Python problem - qgispython.dll
Sasikumar Kanniyappan qgis.developer at gmail.com
Fri Sep 2 10:17:42 EDT 2011
Hi Martin,
Could you please point me where can I find packing Qgis document to include
the python path in environment variable using NSIS. (or)
any document where I can find how to configure *QGIS-Installer.nsi* file to
include all path into environment variable. Thanks.
On Fri, Sep 2, 2011 at 1:55 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Fri, Sep 2, 2011 at 10:15 AM, Sasikumar Kanniyappan
> <qgis.developer at gmail.com> wrote:
> > Hi Martin,
> > Thanks for your reply.
> >     I doing some customization work and creating tools in Qgis 1.7. The
> > problem is the newly build installer is working on the development
> machine
> > but it is not working with the other machines. As you said, something
> wrong
> > with the python while creating installer. Please let me know how to build
> > the Qgis 1.7 with python.(Once again the installer is working on my
> > development machine).
> > I am attaching the error screen shot for you reference.(All error are at
> > python start up)
> The screenshots suggest that something went wrong with the python
> path: there are several relative paths ('.\\DLLs' and others). Python
> docs suggest [1] that you should set PYTHONHOME environment variable
> to get correct paths. This may be reason why it works on your
> development machine and not elsewhere.
> [1] http://docs.python.org/using/windows.html
> Martin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110902/12a314ee/attachment.html
